Does NP241 fit a 2002?
3.2K views 5 replies 3 participants last post by  gkesseru
I have a stock 2002 TJ Sport 4.0, 32RH automatic with a 231 transfer case. Will a 241 bolt in? If it does bolt in, do I have to modify anything else to get it to work?
Which version of 241 and from what vehicle
If you mean a TJ rubicon case it will bolt on a TJ 4.0 tranny but will not clear floor without hammer work and driveshafts have to be changed
Worked out for this guy with 2” body lift for clearance
Assume that means 1" Body lift, 1" Motor Mount Lift, Under Cover Fabworks No Body Lift Skid Plate, and Low Profile Transmission Mount?
Does an NP 241J from a JK fit a 32RH TJ transmission?
