In my new 2023 Gladiator Sport, I'm installing the Voswitch JL8000 accessory switch on my windshield pillar grab handle. Everything's done. It's beautiful. I have some road legal SAE Rigid fog lights on the bumper, and some offroad Harbor Freight LED spotlights on the pilar. They all work. It's awesome, but it's always on. Now I'm doomed to have to remember to turn the panel off each time I exit the Jeep. In order to make it work only when the Gladiator is running, I need to connect to an accessory fuse in the fuse box. BUT all the instructions say to use Fuse 52: Cigar lighter. Problem: I had a shop install my winch and they used #52 already.
I've been experimenting with fuse after fuse: Example Fuse F97: Radio. Nope. Didn't work. I found a whole mess of HD Accy Switch 1, 2, 3 and 4 fuses, probably for if I'd gotten the factor accessory switches, which I did not. They don't work either. Perhaps Voswitch knows that only Fuse 52: Cigar works with this switch, and that's why they specifically call it out in the printed instructions.
My question is: Do you think it would be safe to just splice into the red wire at Fuse #52 that the winch is using? That way I can share fuse 52 like the instructions say to. My assumption is that the winch is not really drawing much power. I assume the winch is only using it for the controller.
To my advantage, this Voswitch array has a power draw limiter on it. If I accidentally leave the lights on, the switches are supposed to deactivate if the battery begins to drain past a certain safe point. So...whew. But still, I'd much prefer to have the entire array go off when I shut off the Jeep.
Before I splice in, I just want to hear from others who have more experience with Jeep wiring than I do. This Gladiator is an expensive toy. I don't want to break it while it's still new.
