1 - 20 of 63 Posts
JpFL
Discussion starter · #1 ·
Hello. I have a 2018 JK unlimited. I’m in the process of upgrading the terrible stock system that came in it. The first thing I did was install new front speakers and tweeters. Let me tell you guys I’m not extremely tech or mechanically savvy, but with YouTube and research I usually do ok. After hours(days) of research and hundreds of product reviews, I still don’t know or feel confident in what I’m doing. Ok back to it. So I went with the alpine Spv-65x-WRA. They were easy enough to swap out with the directions and I got those from Crutchfield for right around $200. This was the 2x 6.5” snd 2 tweeters. (Im led to believe that if I use a component speaker I can have the tweeter and speaker by knee and an additional tweeter up top?is this good or necessary?)
Next I went with the Kenwood 7” in dash *pictured- it seemed to have every feature the others had and more, and I got it for $350 not $400. Got bullet reverse cam ($80) and some of those listed accessories that were required and $100 on radio pro steering wheel control interface. Those are at BestBuy and set to be installed on April 4, I can return or exchange any of this up until then. I then bought a sub and amp off Crutchfield. After a lot of research and still some confusion I went with the Rockford-Fosgate 12” p3d4-12 and sound ordinance bass bunker box off Crutchfield.
Hopefully someone stuck through this novel. The only other thing I know I need to purchase right now is the bass knob. Should all of this together make for a sound that can be loud and clear while having the ability to turn up bass and feel it in my soul?
Will this also not be enough and do I need an amp for the front speakers to really get their potential?
Should I return sub and amp and just get speakers for the front to replace roll bar speakers and an amp to crank em?
Overall I’m at around $1400 total already if I have what I’ve purchased installed if I get the speakers for rollbar and amp I’ll be sitting at around $17-1800. Is there a better way to go about this?
I’ve heard the full systems that alpine has for $2000 (without installation, but had speakers subs amp and I think faceplate), snd I’m confident this setup I have will sound much better for a few hundred less with installation.
Beat buy has total tech support for $200 a year. This membership currently includes free installation of almost all car products even if not purchased from Best Buy. This is saving me massive amounts on labor of the stuff I got from Crutchfield. Local audio shops charging 80/hr labor and say every part of this is 3 hours each.
WHAT SHOULD I DO? What did you do or hear that worked great?
I just installed my setup. All in all, it’s not difficult. I installed my amp under the passenger seat, installed the head unit and backup camera. I had already swapped out my speakers and sub. I thought about the bass knob for my sub but was told I really only need it if I would be constantly adjusting the bass and didn’t want to do it through the head unit. I opted against getting it. Here’s what I went with:
I’d say do the install yourself, save the 200/yr over the best buy membership, Crutchfield already gives you free lifetime support with buying from them, take advantage of that.
Discussion starter · #6 ·
What kind of sub did you use? And speakers? How does it sound? Do you have the amp under seat going to speakers or to sub? Or both?
Lol wish I could help I like expensive shit. Running all Memphis with pioneer 4400nex head unit. Been installing custom car audio for years and this just sounds amazing. However it’s gonna be hard doing anything from any manufacture for less then 1500..
Discussion starter · #8 ·
Forget the PAC module. It's not advanced enough. You want the Idatalink Maestro Can Bus adapter. You will get more out of it than the PAC
iDatalink - Maestro - Maestro RR
Do you think the PAC I have will prevent me from seeing gauges and what not in dash? I think maestro is about same price I should be able to swap those no problem
Discussion starter · #9 ·
Well I’m currently at around 1500 and about to spend a few hundred more on other set of speakers and another amp. What system do you have? I couldn’t tell too much from the pic. I don’t mind spending if I can rationalize for the quality
I am almost done with my set-up. only thing left to do is install Subwoofer. I installed Pioneer 4200NEX with a complete Hertz 6.5" Mille Speaker Components. IT ROCK's!! I'd save the money and install yourself. Its really pretty simple. Has anyone ever installed an amp in the rear cargo storage area? My top is off 100% of the time in the summer and would like to at least keep it out of site if i have my doors off.
I have pioneer 4400nex head unit
Memphis mojo 12” sub
Memphis viv1500d amp
Memphis viv 600 4 way component amp
Prolly little over 3000 but the sound quality is insane and it hits hard if I want it too. Installed myself and build custom box myself. You can prolly go with a lesser sub and sub amp and still be happy .. I just like it extremely loud and it still sound amazing with any music genre I want
If you have room in rear cargo then that would be a good place. On the other hand I have 3 amps and a sound processor under the front seats. I bought some extra black carpet which curls up over the edges of the amps so you can't see them at all, even with the doors off.
Good luck with the BestBuy install, labor is one thing I would not want to save money on.
Chances are BestBuy installer will be a high school kid still learning how to actually install.
An actual local audio shop is more than likely someone thats been installing for years.
Let alone giving your money to another big box store vs a local owned business, it is your hard earned money so you are free to do what you want with it.
Only thing I see thats missing is a wiring kit for the Sub Amp, Power/Ground and Signal wire.
Welcome to the Forum.
Pretty happy with that 4400nex?
1 - 20 of 63 Posts
