Hitch wiring harness
1 reading
6.8K views 10 replies 5 participants last post by  Bob Sanders
I bought a 2015 Jeep a couple months ago that came with a trailer receiver. However, the plug that connects to the trailer is missing, it has the mount next to the hitch. Does anyone know where the plug may be hidden or if I could buy a wiring harness to install? Thanks, Kody
Most of the hitches have the bracket that holds the four flat socket as part of the receiver. Example is the one from Quadratec.
The factory wiring is enclosed in what appears to be 3/8" split loom flexible conduit. The wire comes with two plugs and is inserted into the wiring harness behind the left tail light. Here is a Quadratec kit with instructions (link in the listing image).
If it's aftermarket tow package then they usually run the plug on the end of a wire and hide that wire/plug under the carpet or similar. When you need it you feed the wire/plug out the back door before closing it. If this is the case then you will find the cord inside near to one of the tail lights.
It is possible that your Jeep has an aftermarket hitch installed. The installer may not have installed the wiring harness. As other's said, it's extremely easy and inexpensive. It plugs into the left tail light harness.
#8 ·
I have never seen a trailer wring harness looped out the rear passenger door to the back. The first thing is it will take a lot more wire than normally comes with them. It sounds more like a home built rig by someone who didn't want to spend the time to run one up the rear.
Another thing is that it would be dangerous and likely to have issue. when turning left, the wire would be able to sag down enough to drag on the pavement. Now I have seen some that were wired into the trunk area of a car and the just opened the trunk and flipped it out and then closed the trunk. Granted, rolling your own from a plug/socket piece (about $4 at HD) and a 25' roll of wire ($12) is less expensive, but a lot more hassle, and the space in which you have to work is very small.
|Not the back (passenger) door. The back TAILGATE door.
Every vehicle we have had was wired that way (aftermarket installs by qualified and licensed service stations). A length of cord in the back that you take out from under the carpet, flip out and close the door/trunk lid. Never had any safety issues with any of them.
#10 ·
If an aftermarket wire was wired that way at a shop, I certainly would never take it back to them . Jeep has provided a safe secure way to insert the trailer wiring harness since at least the 1997 TJ. My TJ had a hitch installed on it when I bought it in 2014, and a trailer wire jury rigged almost like you said, where it was clipped onto the wiring harness in the back, but then it was snaked down into the void behind the left tail light (right past the nice socket and plug that Jeep had installed on all to connect the left tail light) then out and tucked into the end of the rear bumper.
I removed all that and purchased the wiring kit from Quadratec and hooked it into the wiring harness at the point designed for it right behind the left tail light, then out to the bracket to hold the 4 flat socket, and pressed the socket onto the bracket. It is handy right beside the reciever. Hook up the trailler, attach the chains, plug in the lights, test the lights and go. The factory installed harness on my JKU is just about the same, except the plug and socket behind the left tail light is different.
Here are the instructions on how to install the wiring on a JK/JKU: While they say 2007-2013, that's because when this kit came out, the 2013 was the current model. They kit and instructions are good for all JK/JKUs.
