I've got a 2005 LJ; 100% Stock. 117k miles.
Had heavy vibes at 30 mph. After ruling out wheels, determined it was likely the front drive shaft. Had local shop try to assess it, they began by taking off the front drive shaft and it then drove fine in RWD. Vibes totally gone. Appears it the U-joint is shot.
So, I left there with the old drive shaft in the trunk and am trying to decide what to do next. It looks like there are just 8 bolts to install and am contemplating buying a new entire drive shaft on-line and installing it myself.
I'm semi-skilled at working on the jeep. Pretty comfortable with a impact wrench and torque wrench, but that's about my limit. Changing out the u-joints is past my skill set.
My main question is:
1) how hard a project is it to install a new front driveshaft assembly? the bolts all look easily accessible.
2) is there a lot more to it than appears? (i.e. can I just bolt on the new one i get? Is there some extra step (i.e. balancing or something?).
3) If so, any suggestions / input on what to get? RockAuto has the following option for $420.
Any and all input appreciated.
Thanks,
Elvis
Thanks,
Elvis
