1 - 11 of 11 Posts
TIMEMACHINE
Discussion starter · #1 ·
So installation was fairly straight forward and only took about and hour. Unit looks great and sound is great. 2 issues I am having.
1. When using carplay I do not get any sound with I try and make a call? I get music, pandora, but when I try to make a call or text just silence. The calls are going out but no sound.
2. I am not getting anything out of the rear subwoofer. There was an extra 10 pin connector on my factory unit with 3 wires but called tech and they said they were not needed but they didn't know what they were for?
If you have the factory amp these are the instructions that worked for me.
"The factory amplifier only accepts two channels of audio input (left and right). Connect the front outputs of the aftermarket radio to the rear inputs of the vehicle connector"
Thanks for the help. I got the radio to work with your advice. Now I have the phone working fine but as you said, no fade.
I guess I will need to upgrade to a 5 channel amp and bypass the factory amp.
I used the fade when I had my 130 installed. I felt like I couldn't hear the rear speaker bar and everything was coming from the dash. When I put in my new HU I also put poly fill in the rear speaker bar and it made a world of difference. The fader was not needed anymore.
http://www.wranglerforum.com/f274/cannot-stress-poly-fil-in-sound-bar-enough-136035.html
1 - 11 of 11 Posts
