I searched for prior posts and didn't find a consensus on this.
Stock 88 256 with 44K miles. RE 4" lift 1000 miles ago on 33s.
My clutch pedal is going soft at an increasing rate. I could get 100 miles or so and have to top off the master cylinder a few months ago, now I'm lucky to get 20 miles around town before having to fill it up again and pump the clutch to get pressure back on the clutch pedal. Fluid is leaking out of the bell housing.
Y'all think its the internal slave? If not, what? Do you think lifting it and putting 33s on it caused it or is it just random & age?
Anyway if it is the internal slave what's the recommendation and why? Should I replace this with an OEM part, high quality aftermarket part or convert to external slave?
I'm interested in durabilty, complexity of work and price of parts and labor since I can't do this myself.
Also, know of a good shop around ATL?
Thanks!
Thanks!
