Jeep JK 3.8l EGR Valve Replacement
1 reading
206K views 87 replies 51 participants last post by  GoodGuy2k2k
Ok, I haven't been on the forum much lately but I though this may be of interest to some so I thought I would post it up.
If you are one of the lucky soles to be getting one of the several EGR codes such as P0404, P0405, P0406 this may be of interest. First off, don't always assume it is the EGR valve right off the bat, there are other things to look at and verify/confirm. Make certain you are getting the correct voltage to the valve/sensors as well as the reference voltages are correct. The valve is a pain in the you know what to get to so consider yourself forewarned. It is not difficult to replace by definition it is just in a very tight location.
The FSM states to remove the battery, battery tray and upper intake plenum to gain access. This is not necessary. You can gain decent access through the right front wheelwell opening after removing the right front tire/wheel and the inner fender.
To remove the inner fender there are three plastic rivets that attach the inner fender to the fender flare at the rear of the wheelwell opening. I have found it best to drill the center of these out, then take a small yet sharp chisel and place nearly perpendicular to the rivet and strike with a hammer to cut the head off of the rivet. This is clean and quick and does not leave any marks or burrs on the fender flare itself. I have heard of people trying to save these rivets by trying to remove them but it is a waste of time and resources. The NAPA part # for the new plastic rivets is 665-2840.
Here is the rivets I am referring to.
Drill out the center of the plastic rivet.
Sharp chisel to remove rivet head.
Clean, burr free and scratch free hole.
After removing the rivets there are approximately 7 or so of the push in style plastic keepers that need to be removed. These simply pull out with the proper tool. The plastic push pins (Christmas tree looking ones) are a NAPA part # 665-1125. These are generally reusable but over time they do get brittle and break, requiring replacement. These packages are around $6.00-$8.00 each so they are reasonable enough to not skimp on. If questionable just replace them.
You will have to twist the inner fender a slight amount to remove it from the body and outer fender but it should come out relatively easy.
Here is what you should see once the inner fender is removed.
Once I got the inner fender out, I sprayed the four bolts with penetrant to soak the fasteners while I grabbed the required tools. This will aid in removing the bolts.
These two small bolts need to be removed.
They require an 8mm socket and the tube is the one you can see on top of the engine going into the top of the intake plenum. Try not to bend the tube once the bolts are removed. It is somewhat difficult to work around this tube but no sense in damaging it. I was able to use a 1/4" drive 8mm shallow socket and 6" extension and the bolts were not excessively tight at all. They came right out with little effort.
Once you get those two bolt removed you can move on to the ones fastening the EGR valve to the head. The heads on these two bolts are 10mm. Remove the near one first that I am pointing to.
If you have a manual/six-speed transmission you can get a 1/4" drive 10mm socket and ratchet on the back or hidden bolt. However, if you are one of the lucky ones who have the automatic transmission you get the dipstick tube to contend with. There is barely enough room between the bolt head and the dipstick tube to get a box end of a 10mm wrench on it. I am pointing to it here.
If you have the automatic transmission you have two choices, you can remove the bolts holding the dipstick tube into the transmission and the bracket on the back of the bell housing and remove the dipstick tube entirely, or you can place a large prybar in between the engine and the dipstick tube and very slightly pry the tube rearward towards the firewall. I chose option two and felt very comfortable moving it with little effort and gained approx. 3/4" of space without any ill effects to the tube itself.
Regardless which transmission you have, remove the nearest bolt to you first. This is the one furthest away from the center of the Jeep and right in clear sight. Once that bolt is removed place the box end of the wrench of socket whichever you are using on the hidden bolt head. Simultaneously as you pull on the wrench, push on the top of the EGR valve towards the center of the Jeep, rotating the EGR valve. This will aid in breaking this bolt loose and both of these bolts are VERY tight, abnormally tight for only an 8mm diameter bolt in my opinion.
If you have the manual transmission you can simply remove the bolt with the ratchet. However, if you have the automatic you will need to remove the bolt one flat at a time with either the open end of the ratchet or the box end as there is not much room to swing the wrench. If you have available a stubby ratchet wrench this aids tremendously in removing that hidden bolt.
Once the back/hidden bolt is out the EGR valve is free from the back of the cylinder head. Carefully turn it to gain access to the wiring connector on top of the EGR valve. I performed this task last as I could not even get my big ass hands close to the connector with the EGR valve bolted to the head. The connector can be tricky if you are not familiar with them. There is a RED locking tab that must first be removed before attempting to unplug the connector form the valve itself.
This RED locking tab slides out perpendicular to the connector and prevents the locking tang on the connector itself from being allowed to be pushed.
Once the locking tab is removed you can depress the locking tang on the connector and pull the connector free from the EGR valve. This is the sweet honey you were after out on the bench.
Old EGR valve on the left with original gasket and bolts. New EGR valve on the right and the NAPA one comes with both new gaskets required AND two new bolts as these seem to very common to be damaged in the removal process.
NAPA part # for the EGR valve kit is 2-26809.
Installation is in reverse order. Connect the electrical connector first and reinstall the red locking tab.
Once that is completed, place the new EGR valve into position and start the two 8mm bolts (10mm bolt head) and be certain not to cross thread them, they should thread in fairly easy by had to start. I also recommend applying some anti-seize to the threads.
Again a stubby gear wrench works great in removal and installation of that back hidden bolt due to the reduced swing required. Bring these two bolts down evenly to avoid warping or damaging the new EGR valve. Once snug use a longer 10mm box end wrench to tighten.
Once those two bolts are tightened install the new gasket between the tube and the EGR valve and install those two bolts.
Reinstall the inner fender and you are ready to rock and roll.
On a side note, if you are near a spark plug replacement now would be a great time to replace them as the passenger side spark plugs are easily accessible from the fender well. Especially if you are running a dual battery setup as I am. There is simply no room to gain access to the spark plugs from the engine bay/topside.
I hope this is able to assist anyone attempting to replace their EGR valve on the 2007-2011 3.8 litre Jeep engine.
Mike.
Awesome write-up. Thank you!
I was getting an occasional P0405 code. It would go away and come back months later. Last time, though, the jeep felt like it was going to stall at a stop sign. That settled it - new EGR valve.
This thread had everything I needed to get ready, including the Napa part numbers for the fender liner rivets and plugs.
The "hidden bolt" was a pain, but I had a secret weapon... A friend who works as a bindery mechanic in a large printing facility. He knows small bolts in tight places. I showed him the bolt and the tranny fill tube. He said "No problem". Within an hour we had the new EGR valve in. The longer job was swapping out the spark plugs and wires.
I'll never hesitate to yank that fender liner to get to stuff on the passenger side. I can't imagine going over the top to get to the EGR and plugs.
#27 ·
You are right about EGR, but I swapped plugs and wires by coming from the top on 3.8L. No problem at all. The biggest concern was to clean everything and have a steady hand so as not to introduce sand into cylinders together with new plugs. Beforehand, I watched a video on YouTube by some Japanese guy who documented how he did it. I used a U-joint and a click torque wrench.
#12 ·
My CEL light came on while on the interstate back in January in my '08 T&C. It was the first time I had seen that light on and wasn't sure I could make to where I was going, but I got there and got home. It was due for an oil change and the service tech at my dealer saidit was the EGR, but I could drive it, it would not hurt anything except gas mileage. It would cost about $530 to replace (high labor because it was on the backside of the engine). I did not note any significant increased consumption, and about a week later it went off for a few days. I talked to a trusted local mechanic, while on the phone he looked up the procedure and said a bad word. With him it would have been about $400.
I waited until the third week of March and took it to the dealer. Came home with my new JKU Sahara. I am happy, happy, happy. But, did enjoy reading through this to see what would be involved.
#7 ·
The CIL can be quite intermittent until the EGR valve fails completely. The ECM looks at the PID's and there is a certain criteria that must be met to flag a MIL. My Jeep started running like crap several days before the CIL ever came on. My gut told me what the issue was because I had run across it several time prior on other peoples Jeeps. I had actually ordered my EGR valve and had some time in my shop scheduled to replace it when the CIL decided to come on.
If you got a code indicating that is the issue, you could change it now or wait until it actually fails but it may fail at a very in-opportune time.
Personally I would change it when you can decide when to replace it vs. waiting until the vehicle decided for you.:pullinghair:
Mike.
#11 ·
Replaced the EGR valve in my 2007 Wrangler after the engine light came on with the code P0406 for the valve, all was good for about 2 weeks and the engine light is on again and this time it is putting code P0403 & P0406. It seemed to run good before and after changing it Time to replace it again or anyone have any other ideas?
#16 ·
Xlnt post. Thanks! Just getting ready to replace on my 2009 Unlimited X w/ automatic.
Thank you SO MUCH! This write up was excellent! And yes the back bolt is a HUGE PITA! I truly appreciate the help. It took about 3 hours. Fingers crossed the check engine light stays off for a LONG time! 👍🏻
Thanks for the replies guys. I had hoped this would be helpful to anyone wanting to take this on themselves.
Mike.
#17 ·
For Auto trans:
I was thinking about the dipstick problem and think I have a solution to removing that hidden bolt behind the EGR. Use a half moon or obstacle wrench like the one shown below.
If you use one like this gear wrench style version, it should make quick work of the install from an underneath angle. It looks like there's lots of room according the the great pics up top.
#22 ·
We replaced the EGR valve in our 2008 Jeep Wrangler, and now, it won't pass smog (in Calif) Our mechanic said that we have to drive it for a while to reset the computer??? Has anyone out there heard anything like this???
That is correct. After 50-100 miles the computer will reset and all codes will be gone if repaired properly. This is done so that you can't just unplug the battery and eliminate the CEL light for a quick inspection pass.
#30 ·
I a about to replace my 2008 jk EGR, among many other parts that I did and will, and this article would be most definitely very helpful
Thanks a million zmotorsports
Thanks all. I am glad with thread has been of some benefit to others. I did another one the other day and forgot all about this post. Once I got the front right tire/wheel off the entire job from removing the inner fender and back out to installing the inner fender was less than an hour.
Mike.
#28 ·
Thank you so much. This was a life-saver. My mechanic (new-ish in town and needing a Jeep expert) quoted me "$200, $500 or $700, depending on what we find". NFW! Even if we're to break the stupid thing trying to DIY it, I'd rather spend a G and have learned something.
So, $100 in parts and spare tools, probably a good man-day distributed over 2.5-3.5 periods of misery, I finally got the fouling thing in. It seems right, and I cleared the code, but I haven't put it through its paces to verify the install satisfied my error code (P0404, as I recall).
After doing body work, a suspension lift and lots of electrical work with only some jacks, wrenches--and other minor tools, implements and requisit materials--and two bare hands, I have to say this was the most soul-crushing endeavor until I finally finished it up today.
It's bad since there's nothing hard about it per se, if you a six speed at least, but the tight crevices, and almost no visual coordination made me question pretty much every decision I've made in life. I already had ripped out my fenders, so it was like 3 or 4 steps and the reverse. Chrysler, I swear to Christ, may have contracted Lucifer himself for this EGR design. Or some nut they cut loose from his straight jacket.
...OK, hyperbole aside, this job SUCKS, but it's doable--and, by God, no other man is going to tell me I can't do it until I proven to myself so and need to give that man a ton of money to fix my arrogance.
We've all been through those types of jobs, so just be prepared emotionally. I don't where the OP got this information, but I would be up shit creek without it.
The only thing I noticed, or step I deviated from, was installing the new EGR exactly in revererse order from the removal. Without a third or fourth hand, I found that gradually working in the visible bolt and hidden bolt in tandem was more effective, giving that the assembly does have weight and there's no good way to suspend it while attempting to thread in one bolt; I found it impossible to do the hidden bolt first, so I threaded in maybe 2/3 of the visible bolt in order to have a sufficiently sturdy platform from which I could carefully begin the hidden bolt.
Anyway, once the old crap is out, the new stuff goes in with appreciably less frustration. It took perhaps have the time if not a third to finish the job once the janky, nastyass old EGR was out.
Overall, I'd describe the procedure as assisting a medium-to-small sized elephant, made of steel, tubing and sharping, protruding stuff placed in perfect position for an emergency room visit, in giving birth to a born cylandar and then... I guess the analogy falls apart. Point is: you can't see shit. You have your arm(s) jammed up into the bowels of your jeep feeling around for this nub or that bolt until you're more familiar than you ever expected or, more importantly, wanted to be with this stupid assembly.
Peace, my brothers!
#29 ·
1st Post
Thanks for the write-up, I'm very hands on with anything i think i can do without breaking generally.
After attempting this I've come to the conclusion i wont be able to get the 2 10mm bolts off without the use of a trusty breaker bar.
Unfortunately after much trouble my dipstick tube is not wanting to stay out of my way. I've looked around a bit but not seen any bolts or clasps holding it in place (but it sure is held in sturdily in place)
Would someone be able to give a bit of direction or perhaps a picture to enlighten me as to where i can find whatever it is i need to remove to uninstall this dipstick tube so i can get to the back bolts?
Also on a side note, if I'm able to replace this valve how far off would i be from being able to install a lift? Was contemplating going for a RK 3.25" lift and running 35" tires hopefully without and rubbing. Any advice appreciated.
