I'm trying to get the full steering back on my 2004 TJ after a Rocky Road Outfitters OTT steering conversion. The pitman arm is too short to give full steering motion. I bought a WJ pitman arm but the one I received from Rough Country has the 4 larger flat tooths locations are mirror image from the TJ pitman arm.
My question is do you think this a mistake on the rough country part or are the WJ pitman arms not compatible with the TJ. ie: the gear locators are mirror image.
I went the direction of the WJ arm since it was slightly longer and from other forums it sounded like it would fit.
Any info would be helpful, thanks.
Dan
Dan
