JK 2009 - P0420 & P0430
1 reading
6.8K views 20 replies 10 participants last post by  KiwiScott
Hi everyone this is my 1st post here,
I'm in need of some help. I was driving home from work one day when I realized I had a check engine light. Got home and scanned the codes and It came up with P0420 & P0430. I looked up some things that would trigger this, pretty much my cats. I kept driving it for a week now, It disappeared and keeps appearing every 1-2 days. Do you guys have any solutions that I should try?
Do you do mostly short drives? If so replace your pcv and then run a water trickle into your engine for 30min at 3-4k rpm after a good hard 15min run. Give it a good hard 15min run after that and repeat a few times. Change oil and filter. If it still faults after 4 or 5 of these cycles you're up for new cats and possibly 02 sensors. Most likely they're just fouled. If it's out of warranty I recommend Castrol Edge 10w60 after 100k in these as the pcv and egr get too dirty from blowby and oil consumption fouls plugs and cats.
Cheers,
KiwiScott.
Cheers,
KiwiScott.
What the heck do you mean "run a water trickle into your engine for 30min " ???
#14 · (Edited)
Sorry for the slow reply (Covid). Yes I realise it sounds like a recipe for disaster.
I actualitly it's a perfectly effective way to clean piston tops, combustion chambers, exhaust valves, EGR valves and cats. A straw from a wd40 can will only gravity feed a fine trickle. It works best if the engine is hot from a hard drive and kept at temperature during the process by mid rev range. I generally disconnect the duct to the front of the throttle body however some people prefer to introduce the water into the pcv vacuum tube directly into the intake plenum post throttle body.
In a hot engine, at mid revs there is no risk of hydrolock. It's best to increase time rather than water flow rate to improve results. This can be done as many times as it takes to get the job done as long as you take it for a good hard run between 30 minute cycles and keep it at temperature for the duration of the cleaning. Take it for a drive to finish and the change the oil and filter. You'll be happy to see there will be no moisture at all in the oil.
In your case this will steam clean your cats and remaining o2 sensors making them more efficient and increasing the difference in signal pre to post cat o2 which is more than likely what needs to happen to clear your fault.
Cheers,
KiwiScott
Like using seafoam. I haven't dripped water into an engine "carbureted" in almost 40 years, it was used to remove carbon from the tops of the pistons and combustion chambers. You can do damage if too much water is ingested though. Also you need to change the oil after, because some will get by rings and into the crankcase. That was my experience. We used to have leaded gas back then also. Remember some of our members are from other countries and all have different levels of experience. For most on here, and I've been on here for a decade, I would say don't do it. I don't like the seaform products and the like "mechanic in a can" while others swear by them, I polished crank journals with emery paper and a shoelace, when I spun a bearing, and changed rings and pistons with the engine in the vehicle. That's old school and it still works. Now here, "usa" for the most part, we throw fixable engines away and mail order a new one. All opinions on here and no one intends harm. As always, peace. .
#10 ·
I have "steamed cleaned" engine internals by sucking water in through a vacuum port in the past. and seafoam and other such things. people have been using water injection on cars for years....many boosted LS applications inject methanol/water mix(windshield washer fluid) to run cooler intake air temps. Porche is working on a factory water injection system for turbo cars as well. water is only really bad if you suck in way too much and 'hydrolock' it.
#16 ·
Yip, most horror stories are either not true or the water has been applied to a manifold vacuum rather than ported vacuum so they draw more when idling then cool down and hydrolock. Venturies need to be ported vacuum or velocity induced vacuum only. Injection can be run from an existing injector both these options ensure flow only when needed and avoid cool idle with water accumulation.
Cheers,
KiwiScott
#11 ·
These codes are commonly caused by cracked exhaust manifolds. This is a common problem on the 3.8L engine. Pull the heat shields off the exhaust manifolds an look for cracks.
I had both codes on my 2009 and both manifolds were cracked. Pulled the front fenders and the manifolds were easy to get at to replace. After the new manifolds the codes are gone.
#15 ·
I completely agree.
