Ok, those of you with 2 doors disregard. I know, the headrests pop right out. They don't on the 4 door, and they are in the way when looking through your rear view mirror! I did some research and found out how to take them out, but I do have some adults that occasionally ride back there. I happened upon a post about removing the springs that force them up. This allows them to stay down when the seats are up, AND THEY STILL LOCK IN THE UPRIGHT POSITION IF YOU PUSH THEM UP!! This seemed perfect but nowhere could I find a write up! So here it is, easy spring removal write up!
Cost: $0
Tools: Needle Nose Pliers and a flat head screw driver
To start off with, don't take off the the seat covers, they are a PAIN to put back together!
Ok, look at the back of the headrest, while locked in the upright position you can see the springs.
Left Side Spring
Right Side Spring
Now just use a pair of needle nose pliers and pull the spring over to the inside of the spring. Easy as pie.
This is what it looks like all the way off.
And you are done!
This is a picture of it all the way back so you can see. Still locks upright if you need it to!
I know this is really easy... but if you have never seen the inside of the seat, it sounds complicated. I made this just to show you its not!
Easy free mod, that is very helpful IMHO!
Cheers :beer:! Hope this helped someone out there, because I had no idea what to look for when I started this!
Cost: $0
Left Side Spring
Right Side Spring
And you are done!
