Have been running Ion 171 Alloys 2 yrs now. Just noticed only about 3/4 inch thread engagement holding wheels on. Did some research and found specs on longer studs for alloys.
Only by Gods grace have we not had a wheel off yet.
Wanted to share this info:
All Cherokee, Grand Cherokee and standard Wrangler has the same lug studs from the factory. They only change to a different stud if the vehicle came with and alloy wheel.
The factory studs are 1/2 x 20 threads, 1 5/8" long with a front knurl diameter of .623 and a rear knurl diameter of .621 thousandths.
The replacement stud I found to work very well is the studs from the 2003 Wrangler Rubicon.
These studs are 1/2" x 20 threads, 1 15/16" long and have a knurl diameter of .627 thousandths. The larger diameter of the knurl still pulls through the axle hub easily enough and makes a very good tight fit that won't work loose. The longer length is perfect.
The Dorman part number 610-449 is also a hardened stud with a black industrial finish.
USE THESE STUDS, LONGER FOR ALLOYS
DORMAN 610-449
NAPA 641-4265
Originally Posted by GrimmJeeper
NAPA's part number for this stud is 641-4265. Nice find I'll add the info I found on em in the catalog system at work
here is all the info I have on them:
Attributes
Wheel Bolt Head Marks : 449 ABN
Wheel Bolt Knurl Dia. : .627"
Wheel Bolt Overall Length : 1 15/16"
Wheel Bolt Shoulder Length : 11/16"
Wheel Bolt Thread Size : 1/2"-20
Wheel Bolt Threads : Right Hand
DORMAN 610-449
NAPA 641-4265
Attributes
