I put a new engine in our '08 Rubicon a little over a year ago. Predictably, it had a few codes at startup that eventually cleared. All except for a P0403. It ran fine so I just ignored it. But now it's due for inspection and I need to sort it out.
I know the P0403 is an EGR code. The EGR was new with the engine replacement because it didn't look like any fun to replace with the engine installed. I bought a Dorman brand EGR, which as it turns out has a pretty high out-of-the-box failure rate.
3 weeks ago I replaced the Dorman part with a Standard brand part. The P0403 still didn't clear. As an aside, I was previously able to clear the P0403 with a cheap code scanner and it would come back when the EGR monitor ran. Now it won't let me clear any codes.
So I did the trouble shooting per the manual - checking for shorts and voltage at the various pins. The only thing I couldn't do was command the EGR on because I don't have that sophisticated diagnostic tools. Through the troubleshooting, you disconnect the C3 plug from the PCM. I think this is why I now have 9 codes stored.
We've put a couple of hundred miles on it and it still shows 3 monitors not ready: CAT, O2 and EGR. In addition I have P0073, P0032, P0052, P0113, P0118, P0123, P0403 and P0406 codes stored. There's still a friggin P0403 pending. It runs fine so I'm guessing that all these codes are artifacts from when I did the key-on test with the PCM unplugged. I'm just wondering how long I should wait for the monitors to run and for the codes to clear. Or do I need to bring it somewhere to have them cleared (I know this will reset all 8 monitors).
It's 2 weeks past due for inspection. I can get a 30-day fail sticker but that's a waste of my time.
