I disagree with the “rice-burner” sounding exhaust claims, at least with the aftermarket exhaust system I bought.
I was concerned about how it would sound before I bought it, but I did not want a loud obnoxious constant drone and I did not want a quite exhaust. I did want something that made some noise when I punched it. And after reading many posts, people talked about how their exhaust choice was affected about how loud it sounds specifically inside the Jeep while driving. People were talking about how the loud drone was causing headaches and they couldn’t keep conversation because it was so loud. The last and definite no-go choice was for a flowmaster. My personal opinion is that flowmaster should go on nothing less than a V8. A flowmaster will be loud for sure.
After emailing the company, I ended up buying the Dynomax 39523 Ultra Flo Polished Stainless Steel Cat-Back Single Exhaust System. This one has a low idle growl to it and when you punch it, it is noticeable and sounds aggressive. I was picky about my choice because I hate rice burners and was definitely not going to go with something like Borla or whatever other choices they throw on there to avoid the risk of that stupid noise the burners put out.
At speed on the highway there is a mild to moderate noticeable drone, which you can feel the hum while inside the cab. I can tell you that if you are sitting in the back, it will be much louder.
You may want to consider that. I’m happy with what I got, but if I would have gotten the louder option, I would have replaced it immediately.
I also have a Ruggedness ridge snorkel intake XHD I think, and a programmer, so it’s running smoothly. It sounds aggressive from the inside and from the outside. For a V6, it sounds pretty good.
Dynomax gives you some sound clips to hear their exhaust. If this is your daily driver I’d go with what I got. If you’re off-roading or won’t be driving long distances regularly, then by all means, go loud.
Good luck.
