[QUOTEt="Jay2011JK, post: 35369612, member: 85861"]
Pennzoil has the MS Certifications from Stellantis, parent of FCA and is used in production engines. The MS certification numbers are in your owners manual and any oil meeting the listed requirements are good to use.
[/QUOTE]
I was under the impression that the oil companies are provided access to the specification and they did their own qualification testing, and proclaim whether they meet a particular car manufacturer spec, essentially "self-certify".
The only exception I was aware of was GM Dexos, which is a licensing agreement to use the copyrighted logo.
But to the OP's concern about using Pennzoil or any other brand, it's specfically stated in your manual that Jeep recommends using oil meeting MS-xxxx. Read the oil container specifications or the oil maker's website for these specifications which they meet for the specific oil.
If you are concerned about a particular dealership's maintenance, maybe a different one is worth exploring.
Also, registering your Jeep on the Jeep website will allow you to view maintenance records performed by a Jeep dealer, in addition to keeping the paper record you are provided by the dealer.
Pennzoil Platinum is good stuff and in the correct viscosity, it meets or exceeds the MS spec for your Jeep.
