Afternoon All,
Having read a lot of threads about the used oil indicator system (duty cycles, engine loads, dusty roads… and on and on…) I’m going to assume mine is calculating correctly. That being said, when do you actually change your oil?
Do you wait for the percentage to reach 0% or is it advised to change it before it reaches 0?
If it hits zero, is this bad? Does it produce codes in the computer that would make the dealer question me on why I waited so long? For those who keep track of their mileage, how do you handle the indicators percentage if it doesn’t match your own calculations?
This will be my second oil change since owning the vehicle. The first oil change was completed barely 2 months after driving it fresh off the lot. I immediately switched to synthetic as I wanted the factory stuff out after the break-in period was complete. So in that particular instance, I was only at like 85% on the computer. After the switch, I reset the computer to 100% again. This oil change is more "normal" in the sense that I've been driving it all winter allowing the computer to do what its designed to do... counting down... how low should I let it go?
Advice?
Advice?
