Hey Ya'll,
I posted on this issue a couple if months ago but didn't get any feedback per say. Somethin's gotta give cuz I'm stumped. Mechanics are stumped.
History: Drove with check engine light on (small evap leak) for many years. Didn't hamper smog tests. At 161k miles, threw a rod mid Sept 03. Engine swap to 4.0 w/102k miles. Ran well except P0305 code came up. Plugs were new from swap but replaced them anyway. Still P0305. Replaced ignition coil. Still P0305. Engine running fine. Not rough. No stall. Switched cylinder 4 and 5 injectors and reset OBD2. Drove about 160 miles (highway). Light came on - P0305. Now guzzling fuel (10 gallons to go less than 100 highway miles). Took Jeep to mechanic for compression test. They didn't listen when I stated COMPRESSION TEST ONLY and per P0305 code, they replaced plugs, ignition coil, I THINK they said they cleaned the injectors, said they fixed a bunch of connection leaks on the motor, and verbally stated 150 psi all cylinders (no actual report privided). Needless to say, I was furious about charges for redundant troubleshooting (I specifically stated I was aware radiator was leaking and I would address that myself however, they went and replaced it anyway - none if the services they did were authorized and no hard copy documentation was provided... talk about a law suit asking to happen, right?). But I digress.
Meanwhile, the check engine light came back on as soon as I took off from the shop. Verified it was still P0305 (thank you Auto Zone).
So, from what I've learned, the following can be checked off the troubleshoot list:
plug(s)
ignition coil
injector
Valve(s)
Valve seat(s)
piston ring(s)
I was told by mechanic who did motor swap that all O2 sensors showed fine on OBD2 scanner.
Jeep starts without hesitation. Runs a little rough at times but not consistently. Just filled gas tank again and will know if guzzling still occuring later today. Am I down to the following as possible causes for P0305 code and can they be specific to cylinders?
Cam position sensor
Lifter(s)
Automotive relay
MAP sensor
OPDA bushings
Pulse ring
Heeeeelp pleeease!!!
ione
plug(s)
ignition coil
injector
Valve(s)
Valve seat(s)
piston ring(s)
Cam position sensor
Lifter(s)
Automotive relay
MAP sensor
OPDA bushings
Pulse ring
ione
