P0369 - Camshaft Sensor Guidance
1 reading
20K views 10 replies 8 participants last post by  Donny O.
Last night my 2016 Jeep JKU went into limp mode and the check engine light came on. The code is P0369 - Camshaft Position Sensor B Circ Interm Bank 1.
I went and picked up a new sensor and can replace it easily, but I believe (correct me if I'm wrong) there are two camshaft sensor locations and I don't know which one I am supposed to replace. I would have replaced both but they one had one sensor in stock. Can anyone let me know if sensor B Bank 1 is driver or passenger side? Thanks.
be sure to check the wiring very close also as I had issues with my passenger side cam sensors and it was the wiring not the sensor
I've been dealing with the infamous P0369 traction control debacle for 5 years. Hit a crack in the pavement and dash would light up.
Replaced both camshaft position sensors twice ..oil change with additives with no solution.
Finally could see a cracked wire on the passenger side camshaft position sensor plug. Cut out the plug spliced in a new one from Amazon with PLENTY of slack.
Couple hundred miles off road in Avi Kwa Ame National Monument and Mojave Preserve with no issues.
#7 ·
Welcome to the forum @Nevadape .
This is a two-year-old thread, so you may not see many comments on it,
It was a good piece of insight though, Thanks for posting it
#11 ·
I didn't do the initial repair or the 2nd repair myself either. it was in the shop right after buying it for something else and they noticed the hack job repair and re did it properly. but the passenger side had no 5v so they tapped into 5v somewhere near the 5v for the drivers sensor and ran it to the passenger side.
if you have 5v and ground then that is not your problem. follow the data wire maybe
