I have a 2002 TJ that will not start. Battery was bad when I got it I replaced it but after it would not start. It cranks but no spark. In my root causing I have replaced the coil pack (2 were defiantly bad), replaced camshaft sensor. Adding gas to intake gives nothing so I didn't think fuel pump issue. However it doesn't seem that the pump is running (don't hear it). So I wanted to see if I got any codes off it and borrowed an OBD but if failed to read anything at all. Failure to connect. Tried in on my other 2002 TJ and worked fine so not the OBD unit.
So my thought is PCM is bad, which is why it isn't getting power where it is needed to start. (coil pack and fuel pump). However I was also thinking it could be wiring/connector gone bad. I am unsure though how to test if the PCM is really the cause before I drop more money on something I don't need, on a Jeep I never intended to keep.
For ref I bought 2 at one time as seller was only doing it as a package. I intend to fix and keep one and the other one was to do a little work and sell to put money towards the TJ I kept. Both are the same model but the PCMs are not the same so I don't think I can swap and run the OBD test on the other Jeep. Working TJ is 56044477AD and non-working TJ is 56041945AF.
Any help on how to test a PCM or wiring to figure out which is the problem would be appreciated.
