Pedal Monster Anyone?
1.8K views 2 replies 3 participants last post by  Jay2011JK
Has anyone tried a Pedal Monster on their JK? I'm curious to know if it's worth it.....I just know there seems to be a delay in the accelerator pedal that I need to go away!
My current set up is:
2007 JK Sahara 3.8L
42RLE Auto Trans
4.10 gears (Swapped the front Dana30 out with a Rubicon Dana44)
34" BFG KO2
I used a Superchips tuner to correct the tires size and gear ration in the ECU
That's all I've done so far...
Same year and gear ratio, except mine is a manual, and I use the Pedal Commander (not familiar with Pedal Monster) and really like it. I have found it to make a huge difference in throttle response. It’s not like it improves the acceleration times or top end speed (I say in jest) but it’s certainly noticeable in feel.
Banks Pedal Monster.. I have run for 2 years on the 21 Mojave.. Yes initial throttle response improved significantly .. no issues .. I don't disconnect when going in for state inspections and warranty; MY local dealer service dept mgr and techs are cool performance dudes. Keep that in mind if your relationship isn't cool with your dealer for warranty work.
