Rear Tub Cut Help/Ideas
1 reading
4.8K views 2 replies 2 participants last post by  Cb93yj
I've got a set of 33x12.5's on my rig and a 3in suspension lift. I'm planning on getting 1in shackles and maybe a 1in body lift to make more room however really don't want to do the body lift. The tires in the rear rub terribly on the trail at full flex and I've been wanting to cut the wheel well a bit in the back to make more space but I am curious as to how some others have done it. Any ideas and of course pictures would be awesome. Thanks.
Put the tire in full compression in the driveway. Take a felt pen and trace a line say 1" all around the tire. Some guys cut to the line with a recipe saw. I used a grinder, metal cutting wheel. I then used the cut piece to trace a line on the opposite side. You will be limited at the front by the body structure but the main concern is for vertical travel.
Before you start trace a line around the outside of your flare. Make sure to stay inside that line. AND measure up inside the wheel tub. You don't want to cut past the wheel well either.
Grind, polish, smooth the cut edge and if you are anal like me you could use a body hammer / dolly to fold the edge in. A bit stronger and a nicer finish... like the factory edge was. Then prime/paint etc.
The only area which really needs trimming is the rear edge. It is possible to get all the clearance you need just trimming that back edge. But still make the marks by tracing a line with the tire fully stuffed.
Perfect thanks! You're right the rear edge is where I'm constantly hitting and what needs trimming however I just didn't know how I might go about cutting it. I've cut the front and used a body hammer and a sawed sledge handle to flare the portion that touches the tire out then smoothed. It's not perfect but gets the job done prior to getting tube fenders.
