Like many here, the PO(s) of my 94 2.5L YJ have half-a$$'d the electrical work. I've got a jumper wire going from the ignition, by-passing the dash fuse box straight to the power center; I found the heater wires cut behind the fuse panel and an "in-line" 30A fuse added, etc. Tired of tackling these one by one; not to mention the "yet to be found" problems, so I bought a used dash wiring harness to basically start over.
The dash is completely taken apart (doing other things_see Pic) so its wide open and accessible. That's part of the reason I'm doing it now ... another "while I'm doing this" project.
The used harness comes with the fuse panel and covers everything under the dash. Radio and speaker wires are cut, but that's no problem. The harness should arrive next week.
My plan is to start at the fuse panel and disconnect the old and reconnect the new one-by-one.
Before starting, any "lessons Learned" would be appreciated, should be fun in a twisted sort of way!
