Shaking mirror
11K views 8 replies 5 participants last post by  fredbama
I've noticed my driver side mirror shakes really bad once I get up to speed. My right one is real steady and you can see everything behind you but the left will shake so bad I can't focus to see anything. Is there anyway to tighten the mirror to stop the shaking? I have power mirrors
There are two torx screws on the inside of the door that mount the mirror assembly to the body. On the bottom of the mirror there is a screw that mounts the mirror head to the rest of the mirror.
#7 ·
The mirror has been hit or hit something. the missus is the same way. The mirror is loose inside the housing. It will hold an adjustment but is loose and vibrates on the road. I have a replacement for her that I need to swap.
She was drag racing the kid across a mud flat and they both fell into a rut. The mirror smacked the kid's sport bar. I actually recorded it. I have to find it. Anyways, I know why her mirror is loose.
Bob K.
My 2011 did the same thing on the drivers side. I swiveled my mirror as far as it would go, and with a flashlight, found a screw that was missing. It attached the mirror to the frame. I found a screw to put in it, swiveled it back, and it fixed mine. I am sure warranty would probably fix it, but I didn't want the hassle.
