Hopefully I'm putting this thread in the correct place..
I recently got an 09 Wrangler 2 door with half doors (soft upper, metal lower). It started to warm up a little this week so I decided to make use of the Sunrider feature and even considered just taking the whole top down. Unfortunately, I'm having trouble getting the top to flip back from the top of the windshield. I've watched numerous how-to videos but none of their Jeeps look exactly like mine, I assume due to the half doors. Basically, I unlatch the front by the windshield, slide the plastic sleeves on each arm forward, press in the clips on the top of the door frame, and then try to lift the top up to fold it back. The top lifts up maybe a couple of inches and then won't budge. It appears that there is a strip of plastic stitched into the top which slides over a plastic piece along the top of the door frame. I cannot get this strip to easily slide off of the door frame and am afraid that I will break something if I force it more than I already have. When I lift up, it acts as if it wants to take the entire door frame with it.
I've attached some pics to give you a better idea of what I'm talking about. Any help would be greatly appreciated.
