Squeaky clutch pedal
1 reading
18K views 5 replies 2 participants last post by  lpadd
I wouldn't use wd40 on much of anything, but you might be able to figure out where the issue is by spraying a small amount in each of those locations one at a time to determine where the squeak is coming from.
If it's the bushing they are available at the dealer for around $5 and it takes no tools to install them. They simply slide over the clutch pedal pin, then the master cylinder rod clips on. Here's the part# and a picture of the bushing.
Clutch Pedal Bushing 254D Bushing Dealer Part # 4643448
If it's the switch, try applying a little white grease to the master cylinder push rod.
