I brought this up in my check engine light thread but I think it would work better as it's own thread.
My 1990 YJ has had a 1992 4.0 swapped in so the original 1990 tach won't work off the 1992 ecu signal so it instead must be run off the negative side of the coil.
I spliced a wire into the negative (green with a black tracer) wire on the coil and ran that to c5 on my bulkhead connector. With the engine running I get power and ground to the tach, and I'm getting around 13.89v from the signal wire but the tach just sits at zero. The needle twitches the tiniest little bit when you turn it on but that's all you get.
Am I doing this wrong or is this thing just busted?
