What is the proper way to remove the long black plastic panel (trim panel) on the inside of the JK tailgate?
I started to remove it, but got concerned I was going to bust the plastic tabs along the top edge.
Is it held in place by spring clips, similar to the grill, and do you pull it out from the bottom, or squeeze the top down to remove the plastic clips first?
I want to run CB coax cable alongside the third brake light wiring, and out the grommet.
