Transmission identification
44K views 37 replies 14 participants last post by  Digger84
The forum's crystal ball is down for repairs so you're gonna have to tell us if you have a manual or automatic transmission, what engine you have, and what model year TJ you have. :)
Ok, that helped. Your transmission is an Aisin AX-15 which requires a GL-3 or GL-4 75W-90 gear lube. The best recommendation for that I can offer is MT-90 from Redline which is a fully synthetic gear lube that meets all of the AX-15's specs and works very well in the AX-15 transmission. :)
What about a manual 2000 2.5l TJ? What type of tranny do I have?
Aisin AX-5 which was used on all the TJ's 2.5L engines until the 2.4L engine came out.
uhh can you break that down for me? I don't wanna walk into pepboys asking for 42rle and not knowing what it is short for
Pep Boys counter people won't know a 42RLE from a Boeing 757, all they need to know is what model year, engine type, and transmission... manual vs. automatic. If you give them a transmission model #, they'll give you a blank stare and ask for year, make, model, and transmission type... auto or manual... that is all you need to know for them to get parts for whatever.
Your new 5-speed transmission is an Aisin AX-15, more commonly simply known as the AX-15. It requires either a GL-4 75W-90 gear lube or a synthetic 10W-30 motor oil. No worries on the seeming discrepancy on those two viscosities, gear lubes and motor oils are measured differently and they are both essentially the same viscosity in reality.
The very best lubricant I can recommend for your AX-15 is Redline MT-90 which is a fully synthetic GL-4 75W-90. You can get it at a discount from www.summitracing.com.
Redline MT-90 would be very to beat for your AX5. Synthetic 10W-30 motor oil has also been approved for the AX5 and AX15. No worries, a 10W-30 motor oil is essentially the same viscosity as MT-90 which is a 75W-90 gear lube. Gear lubes and motor oils are measured on two different viscosity scales.
