2000 TJ Sahara right rear turn signal blinking fast. Bulb is good, so is fuse in glove compartment. Any ideas what I need to do from here? Thanks.
I have found that a fast blinking bulb (on one side only) meant that the flasher relay needed to be replaced.2000 TJ Sahara right rear turn signal blinking fast. Bulb is good, so is fuse in glove compartment. Any ideas what I need to do from here? Thanks.
First pull all the bulbs and look at them. If they look corroded, just use a little piece of sand paper on them. Are all the lights blinking when they're on including the side markers? What if you turn on your hazards?...they use the same relay flasher, so if your hazards work okay, it's not the relay. If your hazards do work normally, cycle them off and on a few times, then try the turn signals.Thanks for the input. I've read several other posts online and some say new relay has fixed the problem. How would I go about cleaning corroded sockets?
I am still learning about Jeeps, but every vehicle I have owned had 1 relay for the turn signals & 1 relay for the hazards.... What if you turn on your hazards?...they use the same relay flasher, so if your hazards work okay, it's not the relay...
They have one combination flasher.I am still learning about Jeeps, but every vehicle I have owned had 1 relay for the turn signals & 1 relay for the hazards.
If you do have 2 relays, and they are the same part number, you could switch them, then see if you have the same situation.
If the part is something that you need, the government will no longer sell it to you. However, if it's a part that you DONT need, they've got a whole stockpile of 'em, just waiting to take your tax dollars away from you.... we have banned selling of parts for the old inadequate cut rate substandard flashers that you only thought you liked better
I think you're on to something here.Try tighting the screws that mount the assembly to the body...
