Windshield washer fluid leak
18K views 7 replies 7 participants last post by  Bullyjeep916
Anyone else had a leak that drips on the top of the driver side spring mount? It's under a platform that the abs brake module sits on. Looks like yet another simple system on the Jeep is broken....
Now I have to take this apart and look for what to fix instead of doing something more productive. :rant:
Washer Pump Grommet
I bought a new washer grommet with strainer that fits on the pump. It was less than $10. When I put the pump back in it was a noticeably tighter fit when pushing down on the top of the pump into the holding bracket. The gasket is a little thicker than the original. We'll see what happens, but I'm confident that this is the fix. The part I used was the "Washer Pump Grommet", Dorman part number 49459.
Washer Pump Grommet
Did this fix end up lasting?
