The under hood lamp has been missing for years and I wanted to replace it. I thought I could use the one that came with a TJ but the connectors are slightly different.
The question is the under hood lamp that originally came with the YJ also a mercury switched on/off or was it controlled by the lights dimmer switch like the dome light?
Also, is the red live all the time. I was thinking I could just cut off the female plug and connect it directly to the TK under hood lamp.
Or should I just go with an LED under hood lighting solution.
