Yukon Grizzly Lockers
14K views 10 replies 4 participants last post by  GuzziMoto
Getting ready to purchase front and rear Yukon Grizzly lockers.
Who's running these? Looking for any input you may have?
D44/D30 Diffs.
Hi, interested here too... what made you consider the Grizzly over the True-Trac?
Grizzly is an auto-locker which will click back in place after a corner, is it a superior locking device? I'm thinking it may be a better choice for the rear if it does more completely lock, however I've yet to hear anything bad about True-Trac's and I personally really like the Torsen design.... You need to hit the brakes if you get one tire in the air to resume power to the tire on the ground. Is this not the case on the Grizzly?
Yes the Grizzly Locker is an auto locker that is 100% traction to both tires but has speed sensing to disengage during turns on pavement. I guess the Grizzly locker is an LSD and a locker built into a single unit. Assuming if you have a tire off the ground and one on the ground with a Grizzly locker that both tires will have power applied without doing anything else. The Grizzly locker seems proven and tested during offroad racing.
