2H or 4H full time?
21K views 15 replies 11 participants last post by  Gottagofast
Trying to settle a question here... Handle of Tito's is on the line.
We both have TJ's. Mine is 99 (3 speed autol) , his is 04 (5 speed auto). Hubby is saying that I shouldn't keep my TJ in 4H full time due to potential overheating of the transfer case (He says OK to run in winter to due to cold weather keeping the housing cold). My logic is that it shouldn't matter, as long as the trans case is in good shape. I like driving in 4H as it feels like she has better response on the road.
Who's right?
Sent from my SM-G930T using Tapatalk
#10 ·
Disagree all you want. There is no maximum speed for 4H. The only limiting factor is road conditions. If they require you to use 4wd, then you probably shouldn't be going over 55. The road conditions are what limits your speed, 4H does not.
To be very specific... 4H and 4L are ONLY to be used in low traction. IE snow mud sand dirt.....
Dry or even wet pavement in are to be driven in 2H only no matter the temperature..... guess you both need to buy each other whatever a handle of titos is.
#12 ·
there are conditions where 4hi at highway speeds is a safe option. sub zero temps on 2 lane highways through the north woods and frozen farms can produce black ice. the roads appear wet but have plenty of traction 99% of the time, but its when the rear tires hit a patch of black ice and send the back of the vehicle sideways that you will wish you had it in 4hi.
I am sure the standard "slow down" response is coming up, but in reality, most modern vehicles are far superior to jeeps for winter highway driving(not 6" snow, but maintained roads that freeze over). with traction control, ABS, and many other advantages, our jeeps are at a major disadvantage. if you cant keep up with traffic safely in 2hi, but you can in 4hi, why wouldnt you use 4hi?
also OP, your husbands 04 auto is a 4 speed
#13 ·
I run 4H at all speeds in the winter on any ice or snow covered or even covered in patches roads. I've had the read end kick out on my in 2WD too many times and that results in a total loss of control. It happens in a flash and I guess it's a shock after getting used to front wheel drive cars. On dry roads of course and especially on turns on dry roads it always 2WD. Try making a super sharp turn in 4WD on a dry parking lot and feel the gears lock up. Not good at any speed on dry surfaces.
#14 ·
If running in 4WD high or low on pavement because of inclement weather you need to really consider stopping distance. In snow in 4 high you can easily get your Jeep up to 70+ MPH. You just can't stop it in a reasonable distance.
#16 ·
You don't ever have to pull over to switch between 2H and 4H.... you reach down any time the road conditions change and shift at any speed.... the only caveat is to make sure you aren't spinning the tires while shifting.....
4H on dry pavement is a bad for your jeep... the temperature doesn't matter.....
Of course 1/4 mile here and 1/2 mile there won't immediately destroy anything but driving in 4x4 on dry pavement should be avoided.
