35 inch tires with no lift?
264K views 134 replies 80 participants last post by  suffolklou
Hello - How feasible is it to run 35" tires with no lift on a JK Wrangler? I plan to mount front and rear stubby bumpers and rugged ridge flat fenders....
#8 ·
The only difference between a 30 and 44 is the size of the ring and pinion and axle spline count.
Sleeve a 30 and dont go taller than 4.56 and you will be fine up to 35s. If you break an axle then go chomos.
I would run 37s and RCVs if I had the 1200 to throw at them
#36 ·
You have the jeep I wanted to buy. Wife said four door but really I think you have the perfect jeep! The LJ was a great wrangler. Yours looks so good by the way.
I agree. Jku too long and need a bigger lift IMO to look good. 4 inch on a jku is bad a though
Not sure what your trying to say here?
It's not the look I am trying to achieve but ability. For rule of thumb most feel that wheelbase to tire size should be 3:1, so the JKU wheelbase is 116"/3 = 38.6666667 so a 39" tire. To do that properly I feel you need a 6" lift. I am running 37" and it barely clears up front and the wheel well is to small in the rear to get a full stuff back there. To do bigger tires than what I have requires a lot more work and money. I will likely stick to 37"s but just go 6" lift to get more breakover clearance that I find is a problem for me and my jeep. This is why I wanted an LJ. Longer wheelbase than a TJ but not too long like a JKU. Plus it looks so good lifted with bigger tires.
I did some googling and it seems like some wrangler owners running 35's recommend the rubicon 4-door springs to provide some lift to accomodate 35's. Can anyone here say how well the stock setup of the 4-door rubicon will handle 35" tires? Is the 4-door Rubicon essentially designed to more easily accomodate 35 inch tires?
#12 ·
:thumb:
You've got some options for running the 35s...however, it's not as easy as just throwing on a set and being done with it. You'll need to address how to carry your spare; you SHOULD address the weak Cs on your front axle, if you're gonna wheel (I'd do it anyway, but that's just me); and, depending on your YM and current gear ratio, you may have to deal with regearing.
That's not even getting into lift/no lift.
You can make 35s work with no lift, as some of the folks pointed out above. But why? Even a minimal lift (TF leveling kit, 2" BB, etc) would give you a little extra clearance, and is relatively cheap and easy to install.
#13 ·
Also need to trim the pinch seam and get either new wheels or spacers. But yeah, you can do it.
What's the reason, btw? I'd vote to add a 2.5" lift to the plan to give you some more clearance.
#18 ·
Definitely add Gussets to the front C's. It's not that expensive to do. Highly recommend sleeves but not a must like the C Gussets
#24 ·
I did it for a few week while waiting on my lift to be installed. It was not ideal. I could not turn full and if I had people in the back seat it would rub on the rubi rails. I think with one inch spacer, flat finders, and a lot of offset you will be fine. It also looked bada$$. IMO
#27 ·
Thanks for all the feedback everyone! Seems like I'm getting some mixed feedback - some people are running 35's without any lift without issue. However, some people seem to be saying 35's without lift have practical limits, even for on-road use.
One guy posted a vid above of a white jeep doing some gnarly offroading with only 1" lift in front. The offroading in that vid is far beyond any type of offroading I would attempt in my jeep. Given these facts and given that I want to keep the gap between my tires and fenders to a minimum, does it seem reasonable to go with 35's and a 1" leveling kit for my next wrangler?
#30 ·
I think this should only be done with a 2 door. JKU is just to long if your planning to go offroad to tackle any thing serious. Just IMHO.
#33 ·
Glad that someone posted this, as was thinking about this as well. Going to get the RK 2.5 lift, as I do want to run 35s, but getting lift kit, wheels, and tires all at the same time would be too much money.
So was planning to see if I can run 35s with just a levelling kit, maybe for a year (with minimal offroading), then get the lift done later...and based on comments and pics here, seems it would work :dance:
