Best way to install dome light switch... ever...
4.5K views 4 replies 4 participants last post by  scottieg40
I'm sure some of you have ran into the problem where your dome lights stay on when you take the doors off. Sure, you can buy those little clips that hold the door-jam buttons down. You can also just take the fuse out. But what about when you want to actually use the dome light? I've scoured the internets and found many solutions but they seemed kind of tacky with wires coming out of the fuse box with an inline fuse going to a switch.
My way is 1000 times better. Without further ado...
Photos provided below
What materials you will need:
A switch of you choice(I used a rocker switch)
2 wire butt connectors 16/22gauge(heat shrink if you want)
2 connectors 16/22gauge(will connect to switch prongs)
2 feet of stranded copper wire 16/18gauge(preferably different colors)
Note: the length of the wire is 100% dependent on where you want to mount the switch
Wire Cutters
Wire crimpers(needle noes pliers will do)
Electrical tape
What now?
1. Go ahead and disconnect the battery of your jeep or pull the fuse(behind the glove compartment, #4 fuse). We won't get shocked now...:atomic:
2. While we're on that side(passenger-side) lets go ahead and disconnect the door jam button. All we have to do here is wiggle that button and pull it and it will pop free. Now take the connector clip off. Tuck or tape the remaining wire away. That's all you do to that side. You could connect another switch to it if you want. Just replicate the switch installation instructions.
3. Back to the driver side. Pull that door jam button out just like the other side, wiggle wiggle wiggle. Cut those wires and splice about a foot of wire for each wire(should be 2 wires). Use the two butt connector splicers and the wires I mentioned in the materials needed above.
4. At this point you can feed the wire into the hole and fish them out and feed them to the desired location and cut the length to your liking. Go ahead and take a drink of that beer too.
5. Crimp the connectors on the end of the wire leads that will slide onto your switch.
6. Plug those connectors onto the switch and WHAMM. You're good to go! Plug that fuse back in and connect that battery. Flip that switch and watch the party light up. :bop:
To mount the switch(optional)
Drill
Smallllllll saw
File
I personally wanted my switch mounted into the plastic cover that goes beneath the steering wheel. So I took a piece of paper and cut out a square to prototype the size of my switch. Once I had that right penciled it in to where I wanted it and drilled out a bunch of holes into the spot sawed it a little bit and filed it down to make it perfect.
In my case the dome light didn't work at all, ever, no matter what I did. Pretty sure the switch was broke when I got the jeep. The same goes for my buddy. This tutorial is an alternative for the inline fuse method for installing a switch. Quadratec sells one for this very reason, so I'm assuming that it must be an issue if they sell and inline fuse with a switch. Just sayin.
