i have yet to see a same side turbo setup on a 4.0. Everything i see goes under the oil pan and comes out on the passenger side of the engine and there is where the turbo is mounted. I have also seen a setup where the turbo was all the way back behind the tcase lol.
The most i've seen people run on the stock internals and bottom end of a 4.0 is 6 psi.
4.0LSahara, on any turbo setup not just the wranglers, above 6psi you need intercooler
I've had experience with turbo Miatas.. there were people on the miata forum running turbo setups at like 12lb with their engines lasting over 200k miles. I'd hope that our 4.0 with say 5-6psi boost would be more durable than a 4 banger with less than half the displacement and twice the boost.
Now as the turbo vs supercharger debate goes.. A properly tuned turbo will make more power than a properly tuned supercharger at the same boost. End result? Turbo > Supercharger.
Here is a dyno chart of the same miata with turbo vs supercharger. Turbo is running at 12 psi while the supercharger ends up at 13 at the end. That supercharger is the twin screw bts which is the most efficient one on the market today.
http://flyinmiata.com/tech/dyno_runs/2.0_uber_vs_2.0_FMII_GT3071.pdf
Keep us updated man, this is going onto subscriptions!!!
