I'm doing an engine swap with a V6 232 from a 1976 CJ-5 (which I have plenty of leftover parts for those in need, including full hard top and clean body) in to an 85 CJ-7. Before the swap the motor ran in pristine condition, no knocks, no sputters, low mileage, ran like a champ.
After the swap, which went great, direct bolt in, power steering lined up, there's a lot of electrical laying around but I'm figuring that out as I go. Right now I just want to get it back to running and work on the ignition system.
Ive got no key and ignition hooked up so I'm trying to go off a positive lead. I've got the + lead running to the +COIL, with the + and - lines running to a connector into the ICU, which has another connector (magnetic sensor) which connects to the DISTRIBUTOR, spark plugs in the correct positions and attached to the coil but we're getting no spark when we turn the engine over. Starter engages, engine turns, no spark.
Kind of stuck here, not sure about all the electronics but I thought running from a + lead would bypass the need for an on/off switch. Any advice is good advice. Thanks.
-JCM
adaptjcm@gmail.com
