just installed a throttle positioning sensor and need to know sequence to clear check engine lite and the code.
Thanks
Mike
98 wrangler 4.0
Thanks
Mike
98 wrangler 4.0
I think turning the lights on drains the stored electricity in the capacitors.Plowboy1970 said:I under stand that, just never heard of using the head lights on and off to clear the adaptive memory. My 95 Neon will loose all adaptive memory when disconnected for some time. But my 98 Z71 never does. For that I use a Snap-on scanner to clear everything.
Will
Aren't your supposed rebuttal and subsequent claims also in print? :facepalm:Believe what you want to believe. Just because someone put it as a sticky makes it true?
Use a scanner that can "see" the deep adaptive memory - you'll see for yourself there is no Easter Bunny.
That's exactly why this country is failing - people believe it's true because something is in print somewhere.
That's like when the tech guy tells you to hit any key, and you respond with, I can't find the ANY key.If you can find the "control" and "Alt" and "delete" on the Jeeps PCM let us know where they are...
You read through the thread?kfdjason7620 said:Unhooking the battery cables and touching them together is how I've always done mine, and while cables are off, turn key on and off, a 1 minute procedure, works on my tj and my xk
Agree. Ur a funny man :rofl:rrich said:See? It still persists even though it's so simple to actually prove or disprove it!!!!
Obama wants to lower taxes!
If you turn in your guns crime will automatically stop!
The world is flat!
I don't care anymore.
DoneTyewilly said:No no, you're all wrong. To clear the memory you have to remove the battery, turn it three rotations counterclockwise, reinstall the battery, unhook the left headlight, turn on your windshield wipers and your hazard lights for 13 seconds while hopping on one foot, rotate your tires, discharge the flux capacitor by removing the muffler bearings and grounding them to the engine block, turn on your right turn signal while reconnecting the left headlight, disconnect your battery, drink til you pass out, wake up, and reconnect your battery. It's that easy. Though if you are in the southern hemisphere you have to go clockwise. This procedure only works if you record a video and post it to youtube though.
