Hello, I just cracked open what I think was my AX5 transmission fill plug on the passenger side, but quite a bit of oil came out which I wasn't expecting. I posted a picture of the location of where the torx bolt I removed is located. This was the correct bolt, yes? Just checking to make sure the fill plug isn't actually the one pictured ABOVE the torx bolt. The AX5 illustration in the 95 YJ FSM doesn't look like my transmission.
At least a quart flowed out which leads me to believe whoever filled it last put too much in.
