Do I have the dreaded tick or just an exhaust leak
1.6K views 3 replies 4 participants last post by  Wolfslash16
2017 152k miles
One morning a few months ago, I start my Jeep and I get the tick but once the coolant temp got up to the 200 mark it stopped. Since that day there have bee a few occasions where after driving at operating temperature and parking for a while where the coolant temp drops to around 100 the tick comes back but stops again when the coolant temp reaches about 200. The tick has not come back at cold start again.
Is this tick or an exhaust manifold leak?
#4 · (Edited)
A lifter tick won't go away with temp, so you can safely rule that out. Exhaust noise is normally worse on cold, then goes away as it warms up. However, the 3.6 only has 4 exhaust "manifold" bolts on each side so it's not likely to be that either, although it's worth a check. One thing it may be is piston slap, I've seen rare cases of 3.6's have piston slap at certain temps if the cylinder bore warms up/expands faster than the piston itself. My personal '17 has done it on rare occasion, doing exactly what you said. It only happens after it warm up to normal operating temp, then is parked/cooled down to 100-150 coolant temp. I can hear it "flutter" on rev down below 1-2k RPM's until the coolant temp hits operating spec again.
