i finished installing the axles i bought with the 4.88s. The rear went perfect. When i finished installing the front i noticed the flange that is connected the the pinion has a little bit of play(i have the driveshaft disconnected). So i thought maybe they did not tighten it so well and decided to change the pinion seal/nut and torque it to 160 which is recommended by adams driveshaft to be able to stop any play but not enough to crush the sleeve. I did this , and there is still play side to side and in and out. The play is very small (1/8) side to side and (1/16) in and out. I went to torque it to 180 to see if it would stop and it stayed the same. Im not sure if its the bearings or crush sleeve. When i rotate the pinion the bearings sound good, im not sure what bad bearings would sound like with a hand rotation of the pinion. I think maybe the crush sleeve is too crushed? When i did remove the pinion flange/yolk and seal i tried moving the pinion up and down and side to side and there was not excessive movement either. What do you guys advice? The gears and pinion are not pitted or anything. Should i keep tightening? Should i change the crush sleeve? If i do, is it as “simple” as getting a new one, crushing it and setting the preload to 10 inch/pounds for user bearings? Would that mess up my backlash? I dont have any special tools as im young and never done a regear but id buy a dial in/pound torque wrench to seat the preload.
