DIY Switch/fuse pod
Finally figured out the photo upload! Here goes again::bop:
I used these on my rear bumper, work great at about $20:
http://www.amazon.com/gp/product/B00...A12A3GM6KYLIDT
Built my own SPOD like relay package for all my lights for under $100 usung mil spec aircraft grade wire and Cooper Bussman's relayfuse combo box:
Welcome to Waytek Wire:
https://www.pegasusautoracing.com/gr...?GroupID=WIRE2
Pre-wired the switch control lines that get run across the firewall and then into the inside pillar switch or switch area. Every other odd fuse slot is actually used to fuse the load feed, pin 30 of relay in my setup, and I used fuse slot 2 for fusing the power run that feeds the switches. This single power run to the switches is low current and is fanned out at the switches, which then each switch feeds back to pin 85 on the associated relay energizing its activator coil when switch is closed. I have only 3 loads so far, thus 3 relays in place:
White Tefzel jacketed aircraft wire, every other green plug is removed and load wires placed once in vehicle.
The main battery line, in red, is also fused between the relay box and battery:
Slotted holes allow slipping over screw heads I placed in the plastic shield in fender wall beside battery:
Screws in place for plate, just tight enough:
I think I got this correct!
The most difficult part is getting all the right contacts and seals. The mounting system is single piece of .060 alum with one 90 degree bend and 4 holes, 2 of which are slotted. DISCLAIMER: I learned to build this from another blog somewhere, it is not original!
