Dynatrac serious performance Prorock 44/60's with 37s?
1 reading
7K views 15 replies 8 participants last post by  Rob50lx
I have read all the forums I could regarding the Prorock 44 combined with the rear Prorock 60 (semi float), and still have not come to a conclusion. Will I be ok running 37" Ko2s (one of the lightest 37s on the market) with this combination? I have seen many claims of bent flanges in the pro rock 60 semi float, but do not know enough information like tire size, etc that caused this. I know Dynatrac claims I can run up to a 37" tire, but want everyone's input. If not tell me what would work 35s, Spyntech hubs, etc. I just want to build a reliable rig. I already have these axles so no I cannot opt for new 60s with locking hubs. I figured if I would run 37s the lightest would be best. I would like to try and play in the rocks and do moderate to difficult trails.
I would think on even a pro rock 44 you could run a lightweight 40... of course most of this boils down to what kind of driving you are doing and taking it easy on the throttle offroad. A 37 will be handled very easily from the 44 and especially the 60 in my humble opinion.
Reactions: M4x4
The semi float 60 will still be prone to rear flange bends just like the 44. With the front 44 you still have ball joints and unit bearings that are smaller than their 60 counterparts.
That said, a light 37 should be fine for most trails. But I would not bounce it hard or hit things too hard.
FWIW we have similar set up on our '18, Teraflex 60/44 combo with a 37" Cooper STT Pro and it's done fine with light to moderate wheeling for several years.
I'm running the Teraflex equivalent of that combo (TF44 and CRD60). Running 37's is a non issue IMHO. Running 40's won't break the axle housing(s) per say, but it would put quite a bit of stress on the shafts/gears, and that would be your weak point. Going Full float would be where you could hit 40's much safer if you wheel hard.
Overall 37s should be perfectly fine with just some expected accelerated wear of bearings and balljoints. I thought the 5x5 ProRock 60 came with some special rear flange/bearing arrangement that reduced the likelihood of bent flanges?
Too late now but you really missed the boat when you ordered those axles. When ordering those axles and considering 37s a wider width should have specified. By going to 68"-70" wide you could have got away 4.75" backspacing or even greater and reduced a lot of stress on the BJs, bearings, and flanges. To me, full-float 8x6.5 or 5x5.5 would also be the preferred spec even at the cost of new wheels. This makes it a lot easier to get off the trail if there is an axle failure. Some complain about the extra weight but it is all at the axle and helps stability and center of gravity. The extra unsprung weight might be a hinderance on high speed Baja stuff but most of us don't do that with our heavy Jeeps.
I'm converting my "polished turd" D44s to full float but I wish I had known better when I ordered my Tera44R over 4 years ago that wider would have been better; and now Teraflex offers 70" wide axles. Yes most people put 37s on stock width axles but wider is better when starting with new axles. I need 2.75" backspacing to maximize the articulation of my 37s on stock width axles.
#10 ·
Crap. I wish someone told me long ago that I will bend flanges or otherwise destroy a 44 on 37's, especially the way I wheel. I'm not easy on mine. I don't beat it with the skinny pedal but bouncing off the frame, rails, undercarriage is the norm.
Stock Sport D44 rear with US made Revolution gear chromolly axle shafts, Core 44 front with RCV axles. 37" BFG KM3's. It's been in this configuration for close to 4 years now and I'm always in rock.
#11 ·
I bent the stock Rubicon rear driver's side axle flange on 35s during a mild day wheeling. I have now had G2 shafts for many years and 37s doing a lot harder wheeling with no bent flanges. It is always luck of the draw but it becomes easier to bend axle flanges the heavier the vehicle and bigger the tires get. At least most times a bent flange is still drivable but annoying. Some people can break an anvil and some people have a lot better luck on drivetrain parts.
