Like the title of the post say the dash brake is staying on like the ebrake is engaged. It started the other when driving home from work. I just did a service this past weekend oil change, new spark plug, checked brake pads and brake fluid everything was good. I haven't had any problems braking either since the light has stayed on. I've done some research some ppl say to bleed the brakes, look at the master cylinder and the senor or switch that detects when the e brake is engaged could be faulty or have a bad contact. Thanks
