will the ecm off of a 95 jeep cherokee 4.0 w/automatic transmission work in a 95 jeep wrangler 4.0 w/standard transmission.
thank youHere's a link to several Factory Service Manuals, thanks to Got it at last. Click on the link and then click on the FSM that's for your year YJ. Go to the 4.0 engine section and look for a diagnostic flowchart.
Dropbox
www.dropbox.com
Other members with FI motors will hopefully chime in with suggestions. The more information you provide as far as your Wrangler and what you've done to cure your issue, the better the suggestions you should receive.
Good Luck, L.M.
Welcome to the Forum!Do you find the problem i have the same exact problem as you swap the ECM and now try to start but dies any help please
tankyou!
