Engine starts on second crank every time
1 reading
9.8K views 20 replies 7 participants last post by  hosejockey61
I've got a bunch of questions and projects, but thought I'd start with a simple annoying one. My '98 with the 4.0L consistently starts on the second crank. It's only started on the first crank maybe one or two times. Crank, wait, crank again - start. When I got it I did an oil change and replaced the distributor cap and wires. Have new spark plugs, but haven't changed them out yet. Any ideas?
If instead of cranking you cycle key on and off three times waiting about 5 seconds between each switch from on to off before you crank then does it start first crank?
If it does i would suspect check valve on regulator attached to fuel pump back in gas tank
You can test of your fuel rail has a Schrader valve pressure port and you attach a fuel pressure gauge and check rail pressure before you turn key to on first time
Why 3 times versus turning key on for a couple seconds before cranking?
I'm living with this also, wife's XJ will start if you sneeze on it must my TJ always second crank. I replaced the regulator atop the fuel tank, but I think the regulator is in the pump itself. Also it could be a dirty/leaking injector, dropping your static pressure on top of your piston.
#8 ·
Mine sometimes sits a week or two before its next trip to the ranch or mountains.
If I immediately crank, it will go 3-4 seconds before starting.
If I turn the key on and wait a couple seconds, it starts within 1-2 seconds...usually 1.
Original fuel pump assembly at 80K miles.
It is leaking down if that happens
Mine has hidden kill switch that disables fuel pump. If I let it sit for weeks and forget to disable kill switch it still starts quick and runs for a few seconds before coughing from fuel starvation. All on residual pressure from 2 weeks ago
98 sport with original pump and under 40k miles
#14 ·
Yep, but it fires almost instantly if it sits for only a couple days.
My first TJ went 200K on original, so I am hoping to put off dropping the tank for a while.
#12 ·
Turning the key on-off-on several times will give the fuel pump more time running so it can get fuel back up to the fuel injectors. My last fuel pump got so bad I had to cycle mine 7-8 times before it'd start.
The cure is simple, replace both your fuel pump and fuel pressure regulator which can be found as an assembly like below. It's leaking and allowing the fuel to drain out of the engine instead of staying up next to the fuel injectors so the engine can start right up.
AVOID LIKE THE PLAGUE Airtex, Spectra, and local store-brand fuel pumps. They will fail prematurely and you'll regret having installed them. Instead, go strictly for Bosch or Mopar, those are the only two brands that hold up.
This is what the assembly looks like that you want... don't buy any of the kits without everything shown here because the leaking can occur in either the fuel pump or fuel pressure regulator... there's no sense betting which is bad so pay a little more and buy the complete assembly as shown.
Make sure the gas tank is as empty as possible before starting the job.
#19 ·
Skid plate holds it up. There are two nuts on the rear that should have a rubber cap on them... Don't take those of until you have the skid on the ground as those are the tank strap nuts. Really easy to break.
If you are going the poison spyder route, you will run into axle clearance issues if you lean your pumpkin back too far. For your money, the Savvy skid will be the far better choice. Also, the poison spyder GTS just wraps the stock skid whereas the Savvy skid doesn't use the stock skid.
