ah...sorry i wasnt better with that statement. It was driving me insane because...well...Jeep doesnt normally have POSITIVE camber...something HAD to be wrong! Had all new axles, ball joints, etc...thought i had done something wrong with the install. tore it apart to reseat balljoints and everything, rotated tires...readjusted control arms...over and over and over. had about 3 alignments done to double/triple check toe settings,...recentered axles 3 times, etc.
thats what i meant by driving me nuts. finally i reached out to Dynatrac and they just simply confirmed that they build in 1 degree positive camber for the PR44 Unlimited. (which, according to the alignment papers...is EXACTLY what i had). ((the larger tires just make it extremely noticeable))
didnt feel any different. i guess i am a horrible one to ask since at the same time of installing new axles, i also put in all 8 adjustable control arms. i went back and forth with the caster angle. starting at 4 and ending up at 6 degrees. so, there was a bit of "change" in how the whole thing felt due to the different caster angles. i cant remember what it felt like beforehand at this point.
No...i was not able to do anything about it. i know that there are shims you can use to correct it, but i figured: 1. they(dynatrac) built it in...why am i changing it? 2. i rotate my tires every oil change, so i shouldnt have any wear issues 3. the shim idea felt like a bandaid to me. i could be way wrong on that...perhaps it is a viable permanent solution, but i was dead set on finding the ACTUAL issue (see the drove me insane part which turned out to not be an issue)...so i never did it.
hope this helps clear it up a little as to what i was saying (or trying to)
