Definitely a ProComp 4" lift. Could tell from the first photo of the front spring with the "tight" coils. Confirmed with the rear track bar mount. So, I'm not a big fan of those. The cam bolts used all around the lift are generally low end. I also see you have Pro Comp twin tube front shocks and Rubicon Express monotube rear shocks. That's not a great combination. I'd update with a matching set.
How much rock crawling do you do? I ask, because some guys don't want control arm brackets because they are concerned about max ground clearance... If I was looking at that, I would put a cam bolt eliminator kit in the front axle and add a set of Rancho Geometry Correction Brackets. The geometry brackets correct a variety of geometry changes that occur when we lift our vehicles.
Then a set of matching shocks... I would use Rocksports.
Is the front a little high? It looks like the rear is lower than it should be with that much lift...
Here's some links with lowest cost I know of, for the items I would do first to make that Jeep drive the way I wanted it to.
JK Wrangler RockSport RED Long Travel Shocks are custom designed and distributed only by MetalCloak. These trail proven, Twin Tube Shocks have proprietary valving tuned specifically to MetalCloak's exacting standards . Features Include: Oversized 18mm Chrome Shafts Double Welded Bushing Eyes...
metalcloak.com
JK Wrangler RockSport RED Long Travel Shocks are custom designed and distributed only by MetalCloak. These trail proven, Twin Tube Shocks have proprietary valving tuned specifically to MetalCloak's exacting standards . Features Include: Oversized 18mm chrome shafts Double Welded Bushing Eyes...
metalcloak.com
