Turned on JScan and messed around a bit. The vent mode doore actuator is called “Front Mode 1 Actuator.” I monitored three settings, as seen below:
Key ON, engine OFF (engine could be on, but I was in the garage with garage door closed, so not trying to kill myself).
I turned the vent mode knob to the full counterclockwise position (face vent position). This is a target position (and, if the door actuator is working properly, an actual position) of 0. The result:
I then turned the vent mode knob to the full clockwise position (defrost vent position). This is a target position (and, if the door actuator is working properly, an actual position) of 100. The result:
I then turned the vent mode knob to the center/middle position (floor vent position). This is a target position (and, if the door actuator is working properly, an actual position) of 51. The result:
That was at 11:16 PM. I then turned the vent mode knob to the full counterclockwise position, actual and target position 0. I then turned the key to the ACC position so the DLC would still power the Bluetooth dongle and JScan would still operate and monitor the mode actuator. I then went upstairs.
Six minutes later, looking at my phone, the value changes from actual and target position 0 to actual and target position 51. In other words, at rest, the actuator will stop at a default position of the floor vent.
