Jeep makes a squealing type noise when it first starts (video included)
28K views 16 replies 6 participants last post by  Krangler87
So our jeep started squealing when we first start it up, then it goes away in a second or two. I don't recall it making that noise before so this is a new development. It only happens when we start-up, never while we are driving and it goes away pretty quickly. It happens around 90% of the time we start it up.
I tried tightening the belt (it was pretty loose), its at just about 140 using a krikit tension gauge. Here's a video of the sound:
https://youtu.be/VO_2bJkb0Nc
I might try to tighten it up to 160 and see if that helps. Unsure of how I should proceed troubleshooting this? Is it even the belt? lol
Thanks for any help!
sounds like the bearing on the idler pulley is about to go out. They start that intermittent swuacking when they are cold. They are very easy to change.
Reactions: skyzero
Mine was squealing and my battery was was weak, I had it tested and the cold cranking amps were right at the minimum. It being so weak put extra load on the alternator when warming up. The belt was also worn so I replaced both and the squeal was gone.
Sent from my XT1585 using Tapatalk
^^^^ What he said..^^^
My two cents on this one is to let it develop. You can spend a lot of money and time trying to chase down something that's this obscure. If it were a noise from the transmission or the engine that may cause further harm if not diagnosed quickly, I'd be all for it. I think the gambit of what could be wrong has already been covered (idler pulley or battery), and neither of those is going to cost you anything extra because you didn't jump right on it. In fact, it may cost you more if you do!
However, if you're thinking about replacing the belt and checking the pulleys, it's all about the pulley that does spin freely. If it has a good bearing, it will spin a couple revolutions and stop. Ones that spin like a top are on their way out. It's counter intuitive, but check a new one out at the parts counter. Good luck!
#7 ·
WTH are you talking about?!!!? Please explain this logic so that we may understand. Particularly spinning of pulleys......
#8 ·
Skyzero. all of the pulleys should spin freely except of course for the crankshaft pulley. One trick that you may try is to spray the belt surface that contacts the pulleys, not too heavily and not too lightly, moderately with some brake cleaner or silicone lubricant just to see if it affects this noise. If it does, then you know that it is your belt that is making the noise and if the belt has 40K+ miles on it, it wouldn't be a waste of $ to replace it anyway. I hope this is helpful.
#15 ·
Just wanted to update the thread in case people have a similar issue.
After reading Bearbait87's comment and listening to the clip a few times, the more it sounded like if you kept the key turned after the engine turned over. So I went ahead and got a new starter. Just finished installing it and the sound is gone! :D
Thanks again everyone for the feedback and comments!
